How to send waveform data between loops?
I'm trying to write a programm, that in one thread aquire signal, send the data to other loop, which parallely process the signal.
My queues are not working due to not sending the complete qunks between the loops. Only two values are sent.
What am I doing wrong?
Thanks for help. The sample code is below
(3,736 Views)
Have you tried to simplify your code?  What happens if you remove the Queue and just run the Producer (top) loop by itself, maybe with a Stop wired to the Stop Indicator of the While Loop?  [Make a copy of your VI, then ruthlessly edit the copy, deleting everything you don't need for the test.  It will help you follow your own code if you work real hard at keeping your wires straight.  Do you know about the Diagram Cleanup Tool (which I dislike and never use, but I make my wires straight from the beginning)?  It does wonders for your code ...
(3,701 Views)
Hi Ola.dysko,
                            I have checked your code, and it seems that the Queues are working just fine.  You did set 2 channels with 5000 samples for each, therefore the function "Sound Input Read.vi" will return at each iteration 2 waveforms with 5000 samples each ( so basically, the "2 values " that you have mentioned are in fact 2 waveforms ).  If you place a Waveform Graph in the processing loop, and wire it to the Queue data, you will see all your values.
Denis
(3,679 Views)
Why do you convert the Waveform to dynamic?
Remember Cunningham's Law
(3,655 Views)
I would also argue why even 2 graphs.  But if you really want 2 graphs, then a simple Index Array would have done the job.  We expect more from NI responders.
(3,642 Views)
I'm not sure I follow. Do you mean I should not have posted earlier? I just wanted to understand the thought process behind it.
(3,636 Views)
crossrulz wrote:  We expect more from NI responders.
Notice @DStavilaNI's badge.  It is blue, meaning they work for NI.  You did nothing wrong.  I was just adding to your comment about the converting to the horrible Dynamic Data Type.
(3,633 Views)
