write seperate elements to each individual channel tdms
Hi
I have MC which is pumping data from five sensors , each sensor outputs a high bit and low bit. I have created a VI that reads in the data and converts the string to an unsigned byte array. My problem is that I am having trouble adding each individual element of the array in to its own channel in a TDMS file . Currently all data is being written to the same channel.
(3,306 Views)
What's wrong with the solution you were given in your other thread?
(3,304 Views)
It writes all data to a single channel. So it writes the 5 elements to the same channel instead of in individual channels. I have attached the excel file so you can see whats happening.
(3,300 Views)
Then where is your code that has your writing to the TDMS file?  Did you also wire up the list of channel names?
(3,293 Views)
crossrulz I have attached the VI below. Yes I have set the channels up as x,y,z,GSR,R but all data is stored in the x channel
(3,290 Views)
Figured it out using the convert to dynamic data, it works Smiley Happy
(3,279 Views)
Attached the modified vi snippet.
I normally write data to tdms files using for loops
(3,275 Views)
