How to send data from CANOE to LABVIEW
Hello
How were you able to read data from CANoe, I had no problem sending start and stop command, and I can send data to canoe with the DataExchange command, but then when I send the Free Running request command, I don't get any response on labview
I will appreciate your feedback
Message 11 of 12
(771 Views)
i was trying to map the shared network variable in canoe .could you please explain a bit?
what variables should be used in destination and source?which one is the labview shared network variables?
Message 12 of 12
(229 Views)
