How to segment a 1D array into a 2D array?
Here's a real dataset in a spreadsheet file.
Message 11 of 18
(1,745 Views)
the data seems to be both comma seperated and space (or tab) seperated.  The data seems to be two intigers seperated by a comma and then a tab and the chance for two more intigers or two zeros.  They almost look like coordinate pairs.
Message 12 of 18
(1,741 Views)
No, the comma is the decimal sperator in certain countries. We just need to read the with the correct localization settings. 🙂
So:  11,825 == 11.825
Message 13 of 18
(1,736 Views)
Ahhhh!...forgot for a moment.
Thanks.
Well, then, I am confused...
Is the rule
read data, if zero skip...if nonzero add to array row until next zero is encountered?
Hummer1
"When flying, a number accurately presenting the average granite content of a cloud is of little use."
Message 14 of 18
(1,734 Views)
"Is the rule
read data, if zero skip...if nonzero add to array row until next zero is encountered?"
Yes. 🙂
Message 15 of 18
(1,711 Views)
Or, open the file with Word or Notepad and replace the "," by a "." 🙂
Message 16 of 18
(1,704 Views)
Accepted by gisti87
Try something like this (LabVIEW 8.5):
Seems to work with most typical inputs and can probably be simplified further.
(Still needs a few tweaks, e.g. if the array contains only one element and that element is zero the output is a 2D array with a zero instead of an empty array).
Message Edited by altenbach on 11-17-2009 11:52 PM
Message 17 of 18
(1,693 Views)
That's a working solution, thank you!
Message 18 of 18
(1,681 Views)
