remote front panel
To operate and rune a VI remotely, Is it must for that vi to be in run status on the Host Computer?
or
it can be run without launch it in the hoster?
How?
Thanx
(4,294 Views)
You can configure VI server to call the application remotely.
You can try call by reference and call by invoke methods to do that
suki
(4,277 Views)
To do remote panel, you can follow this tutorial :
http://zone.ni.com/devzone/conceptd.nsf/webmain/8BC90A5F744A482886256BA000681713?opendocument
Hope this help.
Isabelle
NIF
Isabelle
Ingénieur d'applications
National Instruments France
(4,274 Views)
The vi must be in memory on the host computer but doesn't have to be running. If the vi is not in memory remote front panels will not be able to connect to the vi. hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(4,265 Views)
Unfortunely, when you access VI remotely, the "hoster"("server") needs de Vi loaded in memory,so yes, you need to launch labview on server to get it remotely...
If you find a away to load the VI in memory without launch labview, tell me...
Srry if it`s little to late to answer, but better than nothing...
(3,737 Views)
