How to save every image with high fps
The sequence structure is not necessary, the second loop has to wait for all of the images before it starts running.
Message 21 of 22
(1,249 Views)
Not only is the sequence structure not necessary, but (a) bring the Error line through and use it everywhere you can (good practice), and make the second loop a For loop, which will autoindex itself so you do not need a second Stop indicator (it will stop when it has saved all of your images, as that's how an autoindex terminal on the input side of a For loop works).  I also am a great fan of Format Into String -- I would wire the index, "i", into Format Into String, specifying a Format of "%03d.png" (without the quotes).
Message 22 of 22
(1,230 Views)
