Unable to create database with MAX
Hi, im trying to create a database. So I go to MAX, create new historical data and when i want to finish i get the following errror: "Unable to create database: Class error or no such requested class exists en max storage".  Also when i open MAX I get this error:
The nipalsys.dll plug-in caused an exception in the CmxSysExpertManager::InitializeExpert function in the nimax process.
See these files for details:
C:\ProgramData\National Instruments\MAX\Logs\20151207_195659-nimax-000010F4.log
C:\ProgramData\National Instruments\MAX\Logs\20151207_195659-nimax-000010F4.dmp
Any help?
(3,626 Views)
What version number of NI-MAX are you using?
Are you running MAX with administrative rights?  I've had some strange errors from NI-MAX in the past when I didn't have the right permissions to do something that I tried to do.
(3,616 Views)
Im using Labview 2011 with MAX 5.0.0. Tried running as adm but still the same error
(3,608 Views)
LabVIEW 2011 is supported all the way through NI-MAX 14.x, though official support drops with all of the 15.x versions.  Can you update MAX and see if that helps?
(3,568 Views)
