04-01-2015 08:40 AM
Sure thing. The issue here is that I am wokring with the LabVIEW part while another colleague is working on building the Java part of the program and he said that he has programmed it for .NET access. So, assuming this to be true, can you tell me how to go about it?
Thanks a lot Mike.
04-01-2015 09:06 AM
04-01-2015 11:05 AM
Thanks Mike. I'll look into it.
Bharat
04-01-2015 11:52 AM
By the way it is very possible to embedd a window of another application, LabVIEW or not into the front panel of a LabVIEW VI. Its just a pain, ugly, and doesn't give you any features over just having a separate floating window. In Windows a window can be a child to a parent window. By default a window is a child to the desktop, meaning it can move around your whole monitor. But you can set a window to be a child to another window, which makes for some interesting looking UIs, because a window will be in a window and can't leave. You can do things like remove a title bar, menu bar, and disallow resizing on the child window and you get the appearance that the window is part of the existing application.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
04-01-2015 08:35 PM
04-02-2015 08:27 AM
@mikeporter wrote:
Do you have an example showing this? Sounds good.
Sure thing. Attached is a zip that I think contains everything needed other than OpenG.
The code is a little rough. I did this demo in my free time when I learned about parent child window stuff. In case you don't feel like downloading and running it, here is a video of it in action.
http://screencast.com/t/LjlkYzTWKr8J
I eventually took some of this information and turned it into the Multi Panel Interface as demo'd on LAVA.
04-04-2015 04:35 AM
@Hooovahh wrote:
The code is a little rough. [...]
Nevermind. Thanks for sharing your demo: Works like a charm
04-04-2015 06:35 AM
Thanks Hooovahh...
05-19-2017 03:50 PM
I know this is an old post but I found it very useful. Thanks Hooovahh for that.
But I do have one issue. When I try to run the given example with program different than Notepad (in my case it is Repetier) most of the buttons on this program stop working while it is in "child" mode. I am not sure if this could be fixed with some special settings. If anyone has any idea I would highly appreciate it. Thanks.
05-19-2017 04:26 PM
Glad you like it, it was a fun example that I never really ended up using on a real project, partially because of the limitation I'm going to mention...
It just uses normal Windows DLL calls to the UI, so if it doesn't work with your program I suspect it doesn't abide by standard Windows UI components. Like hiding the menu bar is very reliant on using standard Windows menu bars, and some programs (like LabVIEW) recreate their own that replicates standard functionality. As a result things like hide and show menu bar might not work. Move, and resize should work, but allow resize might also only work on programs that use standard functions. I also am not sure what the issues are with 32 or 64 bit software. I'm not sure if there are issues with the OS, Child, or Parent that need the same bitness or not.
