Discard Endpoint(s) error - Endpoint has mismatch with application URI of certificate, while adding OPC UA server on Matrikon UA Tunneller
Discard Endpoint(s) error - Endpoint has mismatch with application URI of certificate, while adding OPC UA server on Matrikon UA Tunneller. Though this error from Matrikon UA Tunneller, I think there is something in OPC UA server configuration that causing this error. I am using OPC UA toolkit in LabVIEW to create an OPC UA server. My goal is to expose my server node to OPC DA client for this reason am using tunneller but while connecting/ configuring the opc server on Tunneller am facing this issue. Any help is appreciated.... Feel free to correct me if am making some mistake....
Regards
Susobhan
Message 1 of 1
(592 Views)
