05-06-2020 11:26 AM
Sorry, never cared about Fortran and won't start to, now. I think there are enough other languages that would be more useful to learn if I felt the need to burn some time. 😀
05-06-2020 12:24 PM
Dear Rolf,
Thank you for your reply.
I mostly agreed with you in this thread. But for the point you just sent, I have something not in common with you. Installing gfortran does not necessarily mean you must know fortran. There are still many packages which have been maintained and being written in fortran, for example, Blas, and HSL http://www.hsl.rl.ac.uk/. Those are being maintained probably because people are lazy to migrate to other languages. But those are being written possibly because of computational benefits. MATLAB even recommends using Lapack and Blas for computational benefits (https://www.mathworks.com/help/matlab/matlab_external/calling-lapack-and-blas-functions-from-mex-fil...). The link you provided me on how to install Blas for Angstrong Linux also requires fortran dependencies, of course.
Bests,
-P
05-06-2020 12:38 PM
Dear Wiebe,
Thank you very much for sending me those things. I did not respond to your comments previously but I was aware and read those.
I also research the optimization package you mentioned (one example: https://forums.ni.com/t5/LabVIEW/Executing-the-SQP-Algorithm-Control-Design-and-Simulation-Module/td...). It seems you must use graphic to represent your optimization problem, I am not so sure for this point. If that, it does not fit my problem as I don't know many constraints and types of constraints (equality constraints or inequality constraints) until input data is received. Also, there are many constraints.
Bests,
-P
05-07-2020 05:00 AM - edited 05-07-2020 05:04 AM
I'm aware that the link I provided includes installation of Fortran. Giving you that link was not meant to imply I had done it. I just used google to try to find possbly relevant links. That doesn't change my stance on Fortran. Mathematical analyis never was my hobby, but only a necessary means to an end sometimes. Fortran I could avoid so far and Blas/Lapack only ever got used indirectly by some library that I might have needed, without me having to know about that or anything else related to it.
05-07-2020 05:34 AM - edited 05-07-2020 05:35 AM
IIRC, LabVIEW uses Blas for some math functions? (Not contradicting what you said: "got used indirectly by some library that I might have needed".)
