12-18-2005 12:41 PM
12-18-2005 01:06 PM
I think there are few solutions.
One is to save it in 6.1. Then you have to find someone to save it for you to 6I and then to 5.1, in your vi you couldn't use any functions that isn't in LV 5.1.
Other solutions is to compile the vi and save it as exe with run time library from LV 7.
Another is that you can build a dll library and use it in your program created in LV 5.1
Thats all for now, I hope maybe some of this help.
bogdani
12-19-2005 01:34 AM
12-21-2005 06:40 AM
12-21-2005 07:15 AM
Hi Simon,
As you mentioned you have written a VI in Version 6.0 and you are opening the same on 6.1:
Just try out these two options:
1.Open that Vi in 6.1 and save it befor running the Vi.
2.There is another option known as Save With Option, you can find that in File--> Save with option.
Just try out one of these hope you will get thru your querry.
Also this attachment will help you out.....
Ashutosh C
12-25-2005 02:19 AM
@simon_zhang wrote:
Dear Ashutosh C.I have a Vi (written in LV6.0) but can't run on lab 6.1,.what is going on,could you please help me. error display as the attached.many thanks in advance.Simon
12-25-2005 08:42 AM
12-27-2005 08:11 AM
If you send me the VI, I might be able to convert it back to 5.1. I might not be able to find a link from 6.0 to 5.1, but I have copies of 6.0 that I could install if required. It's worth a try if it's a large VI that would take a lot of time to rewrite.
