How to rescope global variables on a per-instance basis?
I have an inherited app that unforutnatly makes lots of use of global variables (not the functional kind).  If we want to run two instances of the top-level VI simultaneously without having the global variables collide with each other, what is the least painful way to accomplish this *without* having to build it into an exe?
(2,873 Views)
Accepted by topic author SeanDonner
I'm not sure if it'll work or not, but what would happen if you ran the VIs in two different projects?   I might have to try that when I manage to find some free time.
(2,872 Views)
And when you do, I suspect you will find you are correct.
Spoiler
Not that I know from experience seeing I never use those thingies.
 Smiley Wink
Ben
(2,868 Views)
