How to resample an array to the proper timing?
I have a DAQ which returns the data for each channel as a row vector (1-D array)  The sampling rate is defined by the user, so I know the dt between each data point in the array.  I'm taking 1000 samples at 10KHz.  However, when I plot this array on a waveform chart, the time scale goes from 0 to 1000 (the index of the element) instead of 0 to 0.1 s (time).  I need to get this dt incorporated into the data so when I plot it it displays properly vs time, and thus I can perform an FFT to get frequency content.
(3,291 Views)
You can use Build Waveform to bundle up your array, the dT time and a T0 time to get a Waveform datatype that contains the timing information.
(3,286 Views)
Accepted by topic author jtrout13
Use the Build Waveform to turn your data into waveforms.  One of the inputs is Y (your data), another is dt (time/sample).  You probably don't care about the T0.  You can then take the array of waveforms to the graph and the times will be there for you.
(3,284 Views)
Got it.  Thanks again guys!
(3,275 Views)
