01-27-2016 08:10 AM
Dear Sir
I have data saved in excell file. What I know is that Labview cant read excell file. So can you please guide me in which format I should save data so that it could be read through "read from measurement file.vi in Labview"
Kind Regards
01-27-2016 10:46 AM
Labview can read data from an Excel (.XLSX) file. On the Report Generation pallet, you should find a set of VIs that can read and modify Excel files. More specifically in the Excel General subpallet is Excel Get Data
01-27-2016
11:01 AM
- last edited on
04-14-2025
03:50 PM
by
Content Cleaner
Here's a tutorial for the Report Generation Toolkit.
Note: This toolkit does not come with all versions of LabVIEW. It is an add-on that is only included for free with Professional and above (maybe Student as well).
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
01-27-2016 11:09 AM
01-27-2016
11:11 AM
- last edited on
04-14-2025
03:52 PM
by
Content Cleaner
That's not true, please read this whitepaper https://www.ni.com/en/shop/labview/activex-and-labview.html
However, you can use http://zone.ni.com/reference/en-XX/help/371361J-01/glang/read_from_spreadsheet_file/ if you can save your file in csv format for example https://support.bigcommerce.com/articles/Public/What-is-a-CSV-file-and-how-do-I-save-my-spreadsheet-...
The express vi you mention can read from lvm files https://www.ni.com/en/support/documentation/supplemental/06/specification-for-the-labview-measuremen... or tdms https://www.ni.com/en/support/documentation/supplemental/06/the-ni-tdms-file-format.html
01-27-2016
12:30 PM
- last edited on
04-14-2025
03:55 PM
by
Content Cleaner
Yeah the report generation toolkit is some times included but it requires having Excel installed to read and write XLS and XLSX files. There is another option and that is a toolkit by XLR8.
https://www.ni.com/en-us/shop/product/xlr8.html
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
01-27-2016
12:43 PM
- last edited on
04-14-2025
03:56 PM
by
Content Cleaner
I second the use of XLR8, as Hoovahh said the LV Report Generation toolkit requiers Excel to be installed on the target machine.
Also I have found that since the Report Generation tool kit uses ActiveX it is prone to failure due to minor differences in ActiveX and Excel versions as are the pure ActiveX methods of reading and writing Excel files you will find here.
01-27-2016 03:31 PM
why you do not use write spreadsheet files?!
01-27-2016 03:34 PM
Write Spreadsheet File works for CSV files (comma separated values), which can be exported from most Spreadsheet programs.
01-27-2016 03:50 PM
yes But I do not know what is problem if it work CSV anyway so the remain solution is use report generation as friends mention or use active x that I think there is some example of them inside labview example
