How to read and write input voltage from usb 6008 without using daq assistant and using daqmx? My daq assistant has expired
Message 1 of 25
(3,926 Views)
why did your DAQAssistent expire at all?
Well, LabVIEW comes with a lot of example VIs. They also explain how to use DAQmx functions…
Message 2 of 25
(3,920 Views)
GerdW,
Can you please provide me the link for a small example using NI-USB-6008. No where in the examples there is using NI-USB-6008.
Message 3 of 25
(3,909 Views)
Open the example finder. Look for "Data aquisition" -> DAQmx examples.
When you don't have any DAQmx example VIs at all in your example finder you need to install DAQmx for your LabVIEW version…
Message 4 of 25
(3,899 Views)
There are examples, but, they are not using ni-usb-6008
Message 5 of 25
(3,894 Views)
Hi kdm,
no problem, just try examples for AI/AO…
Message 6 of 25
(3,889 Views)
GerdW,
could'nt find it 😞
Message 7 of 25
(3,882 Views)
How do you configure the channels and aquire the data?
Please help
Message 8 of 25
(3,878 Views)
Accepted by kdm7
Hi kdm,
I use a German LV2011 version so I can only tell you a rough tranlation of the search path in the example finder:
signal i/o using hardware
-> measurement of analog signals
---> voltage
-----> Acq&Graph Voltage-IntClk
Edit:
Configuration and acquisition is shown in the example VIs.
You may read the DAQmx basics offered by NI too…
Message 9 of 25
(3,873 Views)
GerdW,
I did it!
Thanks a lot! 🙂
Message 10 of 25
(3,860 Views)
