How to read and write input voltage from usb 6008 without using daq assistant and using daqmx? My daq assistant has expired
Hi kdm,
do you mind to show a picture of your block diagram?
Message 21 of 25
(799 Views)
GerdW,
It was a problem with wavedorm chart properties. How to set the offset to the current system time?
Message 22 of 25
(790 Views)
Hi kdm,
using property nodes:
Message 23 of 25
(787 Views)
GerdW,
Thanks!
Why is my waveform chart not clear?
Message 24 of 25
(782 Views)
Hi kdm,
you need to clear a chart on your own using the "history" property node.
And you don't need to set the x axis offset in each iteration, once before the loop should be ok…
Message 25 of 25
(774 Views)
