How to read Serial Data from Arduino using labview VISA?
I'm starting to wonder if NI should adopt the same practice other forums practice where threads close after, say, oh I don't know... 9 years.
Message 131 of 143
(3,051 Views)
Already being discussed: Lock old threads.  And this one was only idle for ~1.25 years.  Not too bad considering some we have ran into.
Message 132 of 143
(3,039 Views)
hallo, may you give me that circuit picture what you make?.
because i use labview version 2015. i can't open your vi.
Message 133 of 143
(2,933 Views)
This thread has 133 messages in it.  Who are you asking?
And what is a "circuit picture".  Do you mean the VI with a block diagram?
Message 134 of 143
(2,929 Views)
As a followup to that comment - if you click on the "Options" to the side of a message you can choose the "Permalink" entry.
That will redirect you to the page with the message in some sort of focus.
https://forums.ni.com/t5/LabVIEW/How-to-read-Serial-Data-from-Arduino-using-labview-VISA/m-p/4063995...
Or you can quote the post, like this:
Either of those options might let readers have a better idea what you're looking for without needing to go through many posts and try guess.
GCentral
Message 135 of 143
(2,911 Views)
He/she is Knissman.
About gas sensor MQ2 inrterface what she/he make.
Yes sir, block diagram. May you help me to open it and send me a block diagram picture please ? Cause i have a exercise to make interface of MQ2.
Message 136 of 143
(2,884 Views)
Based on the previous page of posts and the approximate name, I guess you're really looking for this:
@RavensFan wrote:
If you follow the instructions given in previous messages, your VI will be a whole lot simpler, work, and look like this.
Here's the block diagram, the VI in that post (RavensFan's, here) was saved in 2017.
The post a couple of posts earlier, by KnissM, had a more complicated "Gas Level.vi" which presumably was intended to solve the same problem.
GCentral
Message 137 of 143
(2,876 Views)
Thank you so much sir.
if i open that block diagram, it will be this..
Message 138 of 143
(2,863 Views)
I see! (as an aside, consider reading this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019YpFSAU&l=en-GB)
The nodes in the block diagram are VISA Configure Serial Port, VISA Write, VISA Read, Decimal String to Number and VISA Close, for reference.
I would backsave it but I'm currently using a phone.
GCentral
Message 139 of 143
(2,855 Views)
I did some cleaning up and saved in 2015.  Hopefully this works for you.
Message 140 of 143
(2,845 Views)
