How to prgrammatically change the background color of a "number control" inside a cluster
using a property node it is possible to change the background color of a number control.
But how to do this, if this number control is located inside a cluster? I could not found the property of the background color (see attached vi).
Thanks a lot and best regads.
Michael
P.S.: I use a reference, because the color change should run inside a subvi.
(4,212 Views)
Accepted by topic author MichaGue_01
Hi Michael,
insert a "to more specific" function and connect the numeric constant refnum to it. I modified your vi a bit.
See the attachment.
Mike
(4,203 Views)
Rats!  Late again.
Jim
(4,198 Views)
Hallo Michael,
you could also create a reference of that specific numeric by right-clicking it (the numeric, not the cluster) in the front panel -> create -> reference.
(4,161 Views)
