How to write Large datasets to ASCII?
   I am trying to save 200 million double-precision numbers to a text file, (to do further treatment with afterwards), and Labview keeps telling me it doesn't have enough memory.   I have 8GB of Ram, but here's what I've heard - I've heard that Labview tries to keep the entire dataset in memory when using "Write to a Spreadsheet File",  and I've also heard that 32-Labview 2009 can actually only use around 1G of RAM for holding your data in memory (please correct my misunderstandings)
  So my question:  I need the 200M points.  How do I get them from my PCI-5122  Digitizer into a text file?
NI Hardware: PXI-7853R, PCI-5122, PCI-6733, PXI-1036, PCI-MIO-16E-4, PCI-6110
Computer Hardware: Xeon Quad Core - 2.33 Ghz, 8 GB RAM
Software: Labview 2009, Labview FPGA 2009, Vista 64-bit, MAX 4.6, DAQmx 9.0, NI-SCOPE 3.5
(2,671 Views)
Hi noli,
make a FOR loop, run the loop 200 times and write 1 million DBLs each iteration...
Let's do some math:
200e6 DBL = 1600e6 byte = 1.6Gbyte. Just the DBL array.
Now convert that to ASCII, using 10 chars per number: 200e6 numbers *10bytes = 2Gbyte.
In summary your conversion would need (at least) 3.6Gbyte of RAM. No 32bit program/OS can handle that...
Message Edited by GerdW on 04-30-2010 04:53 PM
(2,646 Views)
