How to preserve fonts setting in application .INI file after every build?
Hi All,
I'm using compiled (.exe) application in non-English environment. I'm using application .ini file for change runtime fonts how discussed here. But I don't know how to preserve this file per every build. Currently the every build rewrites one by default.
Could anyone help me find out any workaround?
Thanks in advance,
Oleg
Message 1 of 10
(5,885 Views)
The application-specific .ini file that is in your link can be set in the Build using the Advanced page -- put a check in "Use Custom Configuration File" and point it to the .ini file (which I recommend be in the Project/s Resource folder) you want to use.
Message 2 of 10
(5,862 Views)
Hi Bob,
Thanks you for your reply. But I'm not sure that I'm ready to manage by hand a common section inside this file like these:
server.app.propertiesEnabled=True
server.ole.enabled=True
server.tcp.paranoid=True
server.tcp.serviceName="My Computer/VI Server"
server.vi.callsEnabled=True
server.vi.propertiesEnabled=True
WebServer.TcpAccess="c+*"
WebServer.ViAccess="+*"
DebugServerEnabled=False
DebugServerWaitOnLaunch=False
Currently I've used the post-build action. I'm modifying the .ini file on the fly (see attach). But this is just workaround as it seems for me.
Kind regards,
Oleg
Message 3 of 10
(5,812 Views)
Hi Oleg,
5 steps:
- build your EXE once.
- copy the created EXE.ini file to your project folder (and include it in your project tree)
- edit the copied ini file to include the keys for font settings (see the LabVIEW.ini for details)
- now change your Build Specs (Advanced settings -> "user-defined config file") to use the ini file present in your project when creating the EXE
- Create the EXE again to have your "user-defined config file" included…
Done!
Message 4 of 10
(5,799 Views)
I completely agree with Gerd (and basically said the same thing, but with fewer details, in my earlier post).  The point is that LabVIEW will create a Configuration (.ini) for you when you do the first Build.  Save this in your Project (I suggested the Resource folder where you might have an Icon saved) and adjust the Fonts as necessary for your needs.  Then specify it using the Advanced settings.  No need for a Pre-Build Action (which doesn't always "Pre-Build", as I've documented elsewhere).
Message 5 of 10
(5,772 Views)
Yes, you are both right. But please pay attention on following things:
1. The application .ini file contains a lot of variables that depend from build profile.
2. The DevOps have to manage common section by hand in case of users config
3. The continuous integration/deployment unavailable in this case.
I'm looking for solution that provide the real automation around whole project. Hovewer standard approach also can be accepted for small projects or single application with long life cycle.
Thanks for your help, regards,
Oleg
Message 6 of 10
(5,751 Views)
Hi Oleg,
Create an additional EXE, which acts as an editor for your INI file. So your DevOps don't have to edit the INI file "manually", but can do this within a "safe" environment!
Nobody spoke about "continuous" deployment! You deploy just once, with a predefined INI file.
When you have several installations with different INI files you can create a whole bunch of INI files and several BuildSpecs - or you change the BuildSpec each time to choose the correct INI file…
Message 7 of 10
(5,743 Views)
Hi Gerd,
This is the same as post-build VI but more complicated.
Oleg
Message 8 of 10
(5,720 Views)
Hi Oleg,
well, this is a one-time work - but all your DevOps have the advantage of a nice tool to edit their settings!
Message 9 of 10
(5,714 Views)
I actually prefer the more reusable solution, that takes less work on a new build, and in this case a post build VI does the trick.  As mentioned this same VI can be used on every built EXE, without needing to edit it, or specify a custom INI file to be used each time.
Message 10 of 10
(5,679 Views)
