How to plot multichannel graph taking data from a queue (i.e. points of random channels one by one)?
I am scanning 10 resistors (measuring resistance) using a multiplexer card PXI-2503 and a soursemeter Keithley 2400. As I'm reading data one by one and from each reading create a cluster containing a channel, time, resistance value. Then every cluster is sent to a queue.
Queue is used to write data to a TDMS file and also I would like to plot resistances of all channels on a graph vs time. The question is how to plot multichannel graph taking data from a queue (i.e. points of random channels one by one)?
Message 1 of 8
(5,379 Views)
Hi m@NI_forum,
You can use an XY Graph. In a shift register, you will hold an array of XY graph data, which itself is a cluster of x-array and y-array. When you receive a new point, index to the correct XY data (using the channel #), add your new X and Y points to corresponding arrays, and reassemble your data.
You can use a nested "in place element structure" to access the array element and the cluster elements.
Message 2 of 8
(5,371 Views)
For some reason, I cannot find Build XY Graph VI in my palette. Is there a way to plot without using Build XY Graph VI? By the way, can I download Build XY Graph VI anywhere?
Message 3 of 8
(5,348 Views)
Accepted by topic author m@NI_forum
You can create an XY graph without the express VI, in fact I'd prefer if you did!
Here is an example of building the plot one point at a time. Note that it is not an example of good programming practice (no errors, typedefs, queue release, loop stopping) it is just meant to get you up and running.
Message 4 of 8
(5,343 Views)
Thank you. Could you please write me the name of the Clipboard02.jpg tool? I cannot find it. Unfortunately, I cannot open your VI as I use an older version of LabVIEW.
Message 5 of 8
(5,331 Views)
The function is called "Build Array".  It exhibits "polymorphism", changing its appearance (and behavior) depending on what is wired to its input(s).  Drop one down on a Block Diagram and read its Help entry.
Message 6 of 8
(5,319 Views)
Message 8 of 8
(5,268 Views)
