How to make char array into integer array
          If  i give input unsigned char array as a[]={12, 45, 89, 00, 45, 12, 67, 12} ;
              I want output as follows in unsined int array b[]={12458900, 45126712};
Thanks in Advance,
Harish. G.
Thanks & Regards,
Harish. G.
Message 1 of 12
(5,774 Views)
Harish,
I think this will help you
http://screencast.com/t/T67yJZEjpx
Message 2 of 12
(5,749 Views)
Hi Harish,
You should be able to do this using the following code
You will just need to stick this into a loop and read four elements at a time from the array.
Message 3 of 12
(5,748 Views)
Accepted by harishg92
Hi Harish,
in your first thread you want to create BCD byte arrays from larger integer numbers and now you need to go the same way back?
The basics were shown to you: all you had to change was some simple math!
You really should have sticked to your first thread...
Message 4 of 12
(5,725 Views)
Or without for loop.
Message 5 of 12
(5,716 Views)
Harish. G.
Thanks & Regards,
Harish. G.
Message 6 of 12
(5,708 Views)
              input string is a array of unsigned char elements, in that there is no comma,
        then what is the delimeter i have to use:)
Harish. G.
Thanks & Regards,
Harish. G.
Message 7 of 12
(5,701 Views)
Hi harish,
so it's a byte stream? Convert String to U8 array...
Message 8 of 12
(5,686 Views)
 If you convert into U8 array. its a integer its nt a string,
How you wil give this input to Spreadsheet string.
Thanks & Regards,
Harish. G.
Message 9 of 12
(5,680 Views)
Hi harish,
you don't need SpreadsheetStringToArray in that case. All you need is an U8 array for the conversion to I32 array as shown before!
I only used SpreadsheetStringToArray as I didn't want to type all those numbers in a U8 array constant...
Message 10 of 12
(5,675 Views)
