How to make a while loop stop after "x" number of iterations?
I am a new labVIEW user. I am currently using labVIEW Student Edition 2009. One practice problem I have says:
"Modify the general while loop so that it stops when the stop button is pushed OR when the while loop reaches a certain number of iterations specified in the front panel.
Test you VI with number of iterations = 10 "
I made a VI that stops after 10 iterations, but I used "Elapsed Time" and then a certain millisecond delay to get 10 loops. So anytime the number of iterations changed I woul dhave to refigure the delay. There has to be a better/easier way to do this?
Thanks for any help.
Message 1 of 11
(11,539 Views)
In the old days, you would watch for the iteration count and stop if it exceeds a certain value.
Nowadays, simply use a FOR loop and show the conditional terminal to stop early if needed.
Message 2 of 11
(11,537 Views)
Read the help on the while loop.  Specifically, the part about the i terminal
Tim Elsey
Certified LabVIEW Architect
Message 3 of 11
(11,535 Views)
I would just use a For loop but the problem says modify a while loop so I was trying to figure it out. Its eemed easy until I started trying it haha.
Thanks for the help though.
Message 4 of 11
(11,534 Views)
I did see that about the i terminal (I used context help inside labVIEW). I can get it to display the number of iterations but I have not been able to make it stop after just 10. I spent way too much time on this, I have to be doing something dumb.
Message 5 of 11
(11,530 Views)
Accepted by Coop650
try this?
Remember that the iteration starts counting with zero, so you might need some adjustments, depending on how you are counting it.
Message 6 of 11
(11,521 Views)
If i is greater than or equal to required iterations, stop the loop.  You may need to increment i first since it starts at 0
Yeah, what altenbach said.
Tim Elsey
Message 7 of 11
(11,520 Views)
Thanks guys. I was just working on this and came up with this one and it seems to work. I really appreciate the time you all took to respond.
Message 8 of 11
(11,505 Views)
Remember i starts at 0.  Your code runs one extra time.  When your "actual iterations" indicator says 10, it's really 11.  Take a closer look at altenbach's code.
Tim Elsey
Message 9 of 11
(11,499 Views)
Never ever do an equal comparison involving orange numerics (DBL in this case). Your desired iteration control needs to be an integer (right-click..representation..I32).
You should also do a "greater or equal" comparison for sanity. What if the desired iteration is set to -5, the loop would never stop in your code.
Message 10 of 11
(11,489 Views)
