How to load Windows "On-Screen Keyboard" application using LabVIEW
According to Bijay its working fine on command prompt and manual open on desktop then no point for administrative or any kind of user rights issue.
I have a alternative way to open osk.exe, You can try on system and let me know its working for you or not....
Function available in
Programmes-->Dialogs and User Interface-->help-->Open URL in Default Browser (string).vi
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
Message 21 of 28
(7,070 Views)
Accepted by topic author visuman
I found this on lava-forum.
worked for me.
Message 22 of 28
(7,038 Views)
Is there a way to choose on wich screen the virtual keyboard will open?  I have 2 touchscreens on one computer and I would like to open the osk on the screen on wich the application is called the osk.
Thank you,
Message 23 of 28
(6,879 Views)
Thank you so much it is working for windows 10 OS with the 64-bit processor but I couldn't take the value typed on the onscreen keyboard.
what should i do to get that value?
Message 24 of 28
(5,423 Views)
The OSK works just like a normal keyboard. it sends key presses to the whatever is listening.
You need to either:
+ give a control (e.g. a string) key focus, or
+ catch key down events of the active VI, or
+ use the Input Device Control palette functions to pull the keyboard data, or
+ use MS functions (like GetKeyboardState) to pull the data.
I'd go for the first when possible...
Message 25 of 28
(5,413 Views)
the attached VI is able to show and hide both types of the on screen keyboard (OSK and TabTip).
If it could help someone...
Greetings
Lars
Message 26 of 28
(5,279 Views)
Works for me. Nice.
Message 27 of 28
(5,271 Views)
its working for me
Message 28 of 28
(3,323 Views)
