How to increase the value of a certain constant by a constant amount during each iteration
Hello everyone!
I need to increase the value of the "Temperature" indicator by 5 units for 1 iteration of the cycle, that is, for each step the temperature should increase by 5 degrees. How can it be done? Any form of response would be greatly appreciated. Thank you)
(755 Views)
Accepted by topic author Vladyslav_Savchenko
This example show two ways to do this:
Help the forum when you get help. Click the "Solution?" icon on the reply that answers your
question. Give "Kudos" to replies that help.
(714 Views)
Thank you very much. But what are names of this elements?
(704 Views)
The function on the left is a Feedback Node:
It will start out pointing to the left. Right click and select "Change Direction" to make it point to the right.
The second item is a numeric indicator. It shows I32 to tell you it's a long (32 bit) integer.
Blue wires are integers so you should use an integer indicator. Otherwise you will see a little red dot that
means the software has to convert the number. Try to avoid red dots.
You can change the data type of an indicator by right-clicking and selecting Representation.
(688 Views)
