Showing results forĀ
Search instead forĀ
Did you mean:Ā
How extract numbers from string in labview ?
Hi, I want to get from 2023_04_15_12_12.rar this string 202304151212.
(2,600 Views)
Accepted by topic author Petros_Baghalyan
Scan from String with format specifier "%d_%d_%d_%d_%d" and then format the element back into a string with Format into String and "%d%d%d%d%d".
Alternatively you can also use the Search and Replace String with search pattern set to "_" and the replace string set to "" (empty string).
Rolf Kalbermatter  My Blog
(2,587 Views)
i want to know how many days difference between today and 2023_04_15_10_43 .
(2,563 Views)
Hi Petros,
use ScanFromString to parse into a timestamp - see the help for all the supported format codes.
Then it's a simple subtraction (and division) to get the days of the time span…
(2,555 Views)
Thank you for answered ,can you send sqreen ?
(2,548 Views)
Hi Petros,
I could…
What have you tried so far?
What don't you understand from the LabVIEW help for ScanFromString?
Have you tried to subtract two timestamps so far?
(Why do you need a 2nd account now?)
Spoiler
(2,545 Views)
Thank you
(2,469 Views)
