How to implement this logic
Could you please let me know how can I implemet this logic
if  2.39<x<2.4  then y=4.8
if  2.42<x<2.45  then y=5.0
if  2.47<x<2.50  then y=5.2
All the values are hard coded
Message 1 of 12
(4,752 Views)
As usual, show us what you got.  🙂
Bill
CLD
(Mid-Level minion.)
Message 2 of 12
(4,748 Views)
And what if x <= 2.39?
2.4 <= x <=2 .42?
2.45 <= x <=2 .47?
Or x >= 2.50?
There are holes in your ranges.
Message 3 of 12
(4,739 Views)
Then the value is invalid,
it should be actually like this
2.39<=x<=2.4 then y=4.8
2.42<=x<=2.45 then y=5
Message 4 of 12
(4,735 Views)
I would multiply the value by 100 then wire that into a case structure selector terminal.
The case structure would have 4 cases defined.
239 .. 240    it outputs a 4.8 to the tunnel
242 .. 245    it outputs a 5.0 to the tunnel
247 .. 250    it outputs a 5.2 to the tunnel
Default        it outputs a 0 or some other value that you define that you want to represent as an invalid value.
Message 5 of 12
(4,732 Views)
You could use a formula node from the Structures menu.  It uses expressions similar to C.
aputman
Message 6 of 12
(4,701 Views)
Multiplying by 100 and then comparing integer is always better then comparing floating value. Opt for 'X100'
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 7 of 12
(4,670 Views)
So... what happens if the number has three decimal places?  😉
More correctly stated, I guess you could say "multiply the numbers to be compared by 10^x, where x equals the precision of your most precise number.
Bill
CLD
(Mid-Level minion.)
Message 8 of 12
(4,629 Views)
This is an excellent point.  Given the example, multiply by 100 would work fine.  But you also need to be aware of rounding, which is a whole other issue you probably don't want to think about.  When converting to an integer, the number will round toward 0.
Message 9 of 12
(4,612 Views)
But by multiplying as I have shown, that should result in all numbers being integers... or are you saying that if you specified 0.5 was internally represented as 0.499 you are in danger of coming up with 4 as your integer, not 5?
Bill
CLD
(Mid-Level minion.)
Message 10 of 12
(4,608 Views)
