How to implement single and continuous run?
Hi All:
I add two controls on front panel, a "single" button, and a "continuous " one.
When "single" is pressed, the sub VI will execute only once.
But when "continuous" is pressed, the sub VI will execute continously.
I think I can use a while event structure , which captures the button events,
for "single button clicked event ", I just put sub VI  into the diagram.
For "continuous" condition, I will circle the sub VI with a while loop, inside the event diagram.
But now the problem is :  how should I wire the stop button for this while loop?
I think it should stop as soon as "single " button clicked, because now I am going to switch to "single" state.
Maybe I should wire the single button to the stop button?
Do you have other solutions?
Any suggestions will be greatly appreciated. Many thanks.
Message 1 of 8
(4,850 Views)
 can post your vi or the snippet of what you are doing
Message 2 of 8
(4,842 Views)
without seeing what you have got. remember a while loop always executes at least once. use you single/continuous boolean control wired straight to the stop terminal of the while loop.
As asked for though will be easier to answer if we can see the code
hope it helps though
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
Message 3 of 8
(4,837 Views)
Hi Julia,
Please have a look on this VI.
I think this will resolve your query.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
Message 4 of 8
(4,834 Views)
Why to add two controls, rather keep single 'Toggle' switch:
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 5 of 8
(4,826 Views)
i was suggesting link this mode control to the stop in the while loop
Message 6 of 8
(4,824 Views)
Hi All:
I am really grateful to so many people helping! Thank you all. I will give kudos as I look into more details.:)
Attached are two VIs.           subVI is "LED blink once.vi"
I want to make the LED blink once, when single button is clicked.
And it blinks continously when continuous button clicked.
For the continuous event, I use one more while -event structure,
where I put the subVI inside its "timeout" event, while pass "true" to stop this while loop inside "single mouse down" event.
But the VI runs with problems.
As soon as it run, after I clicked the "single" button once, I can no more click on any other buttons such as continous or stop!
The same problems with the other two buttons.
Seems I can only click on one button as soon as it starts to run, all other buttons failed to respond.
Why ?
Message 7 of 8
(4,791 Views)
Accepted by topic author Julia2013
First of all, I highly recommend using the Value Change event instead of the Mouse Down.
Secondly, you shouldn't have an event structure inside of an event structure.  In general, you should have 1 event structure in a VI.  The reason is because there are many caveats of the event structure, and just using 1 of them alleviates most of those.
What you really want here is a version of the Master/Slave architecture.  You have 1 loop for handling the events and another loop to control your blinking.  You can use a notifier to communicate between the loops.
Message 8 of 8
(4,768 Views)
