How to handle 12Gb/ minute data while writing ti binary file.
Hi  GregS
I tried it also. but the same result i have got. for single channel i am getting 12GB/ min as expected. when i am trying to write all the data from all four  channels at  at once the size of each file falling to the around 6GB. i used "Win32" file format and "asynchronous TDMS" file format along with Binary file format, but no use.As you mentioned in the reply i have tried to disable buffer and i tried to acquire no. of elements in multiples of Sector size., which is also not working. when i tried it (disabling buffer and acquiring in multiples of sector size) with "Binary write" i was getting same error(error Code-1544) as i am not acquiring no. of samples in multiple of sector size. i do not understand why it was happening.
Message 21 of 24
(1,335 Views)
Sorry that i have forgot to mention that i tried to acquire the total no. of elements in the multiples of sector size is 102,400/ms... is it right or not.
Message 22 of 24
(1,332 Views)
Is it too late to mention that you probably want to exclude the disk\directory from the virus scanner? That can kill performance.
I'd say ideally you need a SSD for each parallel file to get optimal performance.
Message 23 of 24
(1,307 Views)
Hey Kiranteja,
I'm curious, how did you get on with this, did you get to the root of the problems?
Cheers,
James
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
Message 24 of 24
(1,247 Views)
