How to give different values to different Indicators
         Please check the below attached vi.Iam trying to read some numerical values(from SS1.vi) and display it in the indicator.?(In RR1.vi).While running two VIs we can see that both instruments(gauge and thermometer) showing same reading.My intension is to display varying values.Inorder to do that can anyone please suggest what changes have to made in SS1.vi.I tried some ways using randomnumber generator and all but not worked..Please help.
Thanks as kudos only:)
(2,533 Views)
Hi danil,
maybe it would help not to display the VISA timeout value in those indicators? Maybe you should display "real" values read from that port?
"I tried some ways using randomnumber generator and all but not worked."
Danil, you should have learned by now:
Show what you have done so far!
Explain, what went wrong and what exactly "not worked"!
(2,527 Views)
Actually Iam trying to do both analog devices displaying different values,also in the same device sometimes increasing and sometimes decreasing values.As in the above attached VI the values are increasing continously.
(2,500 Views)
Accepted by danil33
Hi GerdW,
               I solved the issue and the VI is attached.My next intension is to obtain values from a sensor(hardware provided) and display in those devices as shown in RR1.vi.
              Anyway thanks for replySmiley Wink
(2,490 Views)
Hi Danil,
please try to collaborate with Haazini before asking the same questions here in the forum...
(2,469 Views)
@danil33 wrote:
Hi GerdW,
You have not solved anything.
(2,447 Views)
