How to get out of a String with multiple exponatioal numbers a Number array?
i have a problem with a String i get out of a spectrometer. The original form of the Sting is a XML String included the measurement reslults. With Match Pattern i separate the X values and Y values to two strings.
Now i wanna combine the two Strings to a number Array. But how?
My Y data in the sting is like this:
7.948828125E-07;6.848046875E-07;6.274609375E-07;5.248046875E-07;4.015234375E-07;4.081640625E-07;3.863671875E-07;3.901171875E-07;0.03740484375 ..........
I tryed it with Spreadsheet spring to Array but than i just got this results:
7, 6, 6, 5, 4, 4, 3, 3, 0
Does anyone know how to solve my problem?
Thanks and regards
Felix
(2,108 Views)
Accepted by topic author felixfelex
It worked fine for me.
Though your data in your post looks correct, is there any chance that you are running this on a computer that believes the decimal separator is supposed to be a comma rather than a decimal point?
Because the result of you getting a series of integers makes me think the conversion is recognizing the decimal point and the digits after that.
Try %.;%f as your format specifier.
(2,105 Views)
your are right
thanks!
Would be nice if the solutions a always that easy 🙂
(2,099 Views)
