Image reading, Error -1074395989 occurred at IMAQ ReadImageAndVisionInfo2
I am receiving this error when I run my program. I am unsure why it is happening with the images I'm using.
(2,454 Views)
Based on the error code it sounds like you have an error in the path for the images you are trying to open.
I can't open your vi since I have an older LabVIEW installed.
-AK2DM
(2,423 Views)
The paths work, I am able to display the images when I use an IMAQ ReadFile 2 terminal. For some reason I get an error when using the IMAQ ReadImageAndVisionInfo2 terminal, but this is the terminal I need to use for my program.
(2,419 Views)
