05-05-2017 02:40 AM
Obviously, if I drop that snippet with the 15.3 driver installed, it breaks.
05-05-2017 02:42 AM
In this case it seems reasonable that the cause is really the older NI System Configuration driver version.
05-05-2017 02:54 AM
ok so i dug through the documentation, and this feature seems to be introduced only in the latest version. (search for "cpus" in the links)
http://zone.ni.com/reference/en-XX/help/373107J-01/nisyscfg/property_node_hardware/
http://zone.ni.com/reference/en-XX/help/373107K-01/nisysconfig/property_node_hardware/
so i must've been mistaken and didn't use the cpu-frequency stuff in labview2014,
although i know i used cpu infos from the hardware property node. sorry for that (faulty memory).
regards
