How to get CPU speed on RT devices (PXIE-8115)
Obviously, if I drop that snippet with the 15.3 driver installed, it breaks.
Message 11 of 13
(654 Views)
In this case it seems reasonable that the cause is really the older NI System Configuration driver version.
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
Message 12 of 13
(648 Views)
ok so i dug through the documentation, and this feature seems to be introduced only in the latest version. (search for "cpus" in the links)
http://zone.ni.com/reference/en-XX/help/373107J-01/nisyscfg/property_node_hardware/
http://zone.ni.com/reference/en-XX/help/373107K-01/nisysconfig/property_node_hardware/
so i must've been mistaken and didn't use the cpu-frequency stuff in labview2014,
although i know i used cpu infos from the hardware property node. sorry for that (faulty memory).
regards
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 13 of 13
(642 Views)
