How to generate variable frequency pulse pattern from PCI6624 card
Hello
Is it possible to generate variable frequency pulse pattern using counter , I am using NI PCI-6624 counter/timer card
If it is possible Please tell me how to configure hardware  or how to read the pattern from card i.e from which pin.
(2,649 Views)
Hi
To generate pulse train ,whether I have to connect the  external power supply between vss & Vdd pin Or with out external power supply card will generate pulse train Is it possible to change frequency of pulse train at run time.
(2,643 Views)
