How to generate a signal of rician distribution?
Using LabView 8.2, I'm simply trying to generate random signals of different distributions (Rician or Rayleigh) but I couldn't.
Thank you for your help..
yours,
Ahmad Baraka
(3,149 Views)
If you have any known distribution function, you can create matching random data as described in my following post:
(The random number in the above code is the output of the "threshold 1D array" function.)
Let me know if you have any problems. Good luck!
Message Edited by altenbach on 06-17-2007 10:33 AM
(3,146 Views)
I have the same problem
let me try the soln. in the link and inform you about any problems
Thank You altenbachThank You ,
Also Thank you Baraka for asking this question i was about to ask the same Question.
Sherif Farouk ( ", )
Message Edited by Sherif on 06-17-2007 08:16 PM
(3,131 Views)
