Build EXE using Word Dynamic VIs
Can anyone help solve the ERROR that occurs when I try to Build an executable file which involves Word report generation. I have added the Word Dynamic VIs, but it complains about one of those VIs not being executable - as follows:
An error occurred while building the following file:
C:\Program Files\National Instruments\LabVIEW 8.0
\vi.lib\addons\_office\_wordsub.llb\Word_Update_Table.vi
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the
following information as a reference:
Error 1003 occurred at ABAPI Dist Chg and Save VIs.vi -> ABAPI Dist Build LLB Image.vi -> ABAPI
Copy Files and Apply Settings.vi -> EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi ->
EBUIP_Build_Rule_Editor.vi -> EBUIP_Item_OnDoProperties.vi ->
EBUIP_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  The VI is not executable.
thanks
Fred
(3,490 Views)
I have had the same problem before.  Here is a link to a knowledgebase that helped me out.
http://digital.ni.com/public.nsf/allkb/86256A47004E16D186256A84004CB883
--Brian
(3,483 Views)
Thanks Brian. Useful info. But I have added the excel and word dynamic vis to the right place in the app builder, but it says one of its own vis is no executable :
Possible reason(s):
Any ideas?
(3,476 Views)
Further to my last reply, the VI from :
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\_office\_wordsub.llb
called Word_Update_Table     is broken  (Attached)  ????  I dont even call this vi, but the build seems to need it.
Can anyone fix it?
thanks
Fred
(3,473 Views)
Fred,
 When I opened your VI I noticed that the invoke nodes for the table methods were grayed out.  Which indicates that they need to be relinked.  Once I relinked them (right click on the node and select "Relink Invoke Node") it worked on my machine.  I am attaching my version of the file.  Hope it helps.
--Brian
(3,455 Views)
Thanks Brian
I have been away sick. I cant open your LV9.0 vi because I only have LV8.0, but I will try what you suggested.
Fred
(3,417 Views)
