How to find a requested VI (ie "Please find the VI named..." window/panel) when trying to run a previously created VI.
Hey CJL,
    When LabVIEW asks you to find a certain VI, that means that the VI it needs has probably moved since the last time it was referenced.  You should be able to browse to that specific VI and select it.  Then, the box with a ? on your block diagram will be replaced with the VI.
Brian B
Account Manager
(2,354 Views)
