array constant with numerics- can't see data
I built an array constant and populated it with strings, and I can "size to text" so I can see the contents of the array cells. Good. I built an array constant and populated it with numerics and I can't do that. I can only see one digit of a multi-digit data entry in a cell. How can I expand the cell to see the entire datum?
(2,686 Views)
Just grab one of the little blue dots on the numeric constant and resize the box.
(2,676 Views)
By right clicking on numeric constant, u'll not find the same option for numeric constant array. What u can do is, select the positioning tool and resize the numeric constant to fit the no. and than put inside array constant.
(2,669 Views)
Thank you, that did it. But they are indeed, very very little little blue resizing dots.
(2,662 Views)
