How to do case statement based on array of 3 or more values?
I'm trying to figure how to do a comparison  or case structure...based on the setting of an array of 3 (or possibly more) boolean.
Say I have an array (this is coming in from a serial connection, and I'm coverting it back to array to work with) of [T,F,F]  in this case I'd like to display on a status indicator "STBY"
If the array is set to [F,T,F] I'd like to display in that indicator "ON"
If the array is set to [F,F,T] I'd like to display in that indicator "EMPTY"
I can't figure out how to compare combinations of things....I"m reading in a byte array, and the first 3 bits in this example, determin what I need to display as status...I can't figure how to do with with a case structure.....or without doing some nasty looking and/or comparison chains...
Any suggestions?
Thanks in advance,
cayenne
(2,632 Views)
Accepted by topic author cayenne
You could use Search 1D array and find the first True.
Or you could convert the Boolean Array to a U8 integer, and use resulting integer to determine which case to run.  (4, vs, 2, vs 1)
(2,631 Views)
