Read spreadsheet Line by Line
I am new to the program and i still can't figure out how to have my graph display the data from the spreadsheet one point at a time, i tried using several method which was posted by people to load line by line but i still have yet to find out how.. is anyone able to help me?
(3,400 Views)
First, you have to understand how a graph works and how it wants the data for it to be.
Second, once you learn how to bundle the data for a graph, you can read from your spreadsheet - a CSV file? - and bundle that data in the same manner.
It helps to look at the examples  Help --> Examples
(3,394 Views)
I still don't quite understand how does the VI work, I tried bundle I have no idea which things to bundle up.. Could someone help me?
(3,372 Views)
I found the solution already.. Is there anyway I can delete this topic?
(3,343 Views)
Don't bother asking the moderator to delete it. Post your solution, and mark it as solved. That way if someone else has the same issue they can find this post.
(3,340 Views)
