‎03-15-2012 06:23 AM
Hi ,
I have a graph indicator display the data as below:
Now, I also want to display Y scale's value of each point, just like the following picture showed (It's written in another language). How can I achive this in labview?
‎03-15-2012 07:43 AM
Have you concidered using the annotation list?
You can assign text and location for each annotation.
Take care,
Ben
‎03-15-2012 08:39 AM
‎03-15-2012 12:08 PM
right-click create property node >>> Annotation list.
Change to write.
It accepts an array of cluster where each cluster lets you define the text it location blha blah blah.
It will take some work to develop the code to build a proper array of clusters but it can be done.
hint:
There is a mtehod for the graph that will translate XY to coordinates and should help when building that clusters.
Is that enough to get started?
Ben
‎03-15-2012 08:00 PM
Thanks Ben, I will have a try.
