How to disable a single control field in a cluster in NXG?
I have some troubles with NXG. I have defined a cluster with a variety of control elements. I would like to deactivate a single control element within this cluster. However, I can't find an option to do so in NXG 4.0. There was a very similar question asked a while ago without a working solution.
If I connect my cluster to a property node, I can select the disable option. This, however, only allows me to de/activate the whole cluster. If I connect it to a second property node, I get a type mismatch error, because the property node only sees a boolean. If I choose the value property, I can wire it to a second property node and access the individual values of my control. If I right-click on the control field in on the panel and create a reference, it is always referring to the cluster but not to the entry. Any idea what I can do?
(3,345 Views)
There's no property to get Elements[]?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,308 Views)
At least, I cannot find it. Using the property node, I get the following options:
(3,304 Views)
Accepted by topic author DeWilk
I contacted NI support. The feature is unfortunately not supported yet. They just recommended using the internal help/send feedback function to send a request.
(3,193 Views)
