How to detect Null characters in a binary string
In my application, I'm sending around true binary data in strings and flattened data structures and sometimes I get null characters in the string. I was wonder if there is a way to dectect NULL characters in a string. Thanks for your help.
Josh
(10,013 Views)
Accepted by E=McHammered
Josh,
A null character is hex 00.  If you use Match pattern and make the search string a null, it should find it.  To enter a null set the control or constant to '\ Codes' display and type in 00.
Another way is to convert the string to an array of U8 and search the array for 0.
Lynn
(10,007 Views)
Josh
There are various ways to do that:
1) convert the string into a byte array and look for 0 bytes in there.
2) Using Match Pattern function and a search string containing \00 (enable backslash codes in the popup menu)
3) If it is about replacing/removing them, using the Search and Replace String function and again \00 as search string
4) - 99) various variants and functions in LabVIEW using advanced regualr expressions etc.
Rolf Kalbermatter  My Blog
(10,005 Views)
