FResDir Problem
I am getting an error when calling a dll using a call library node.  The error says Labviewv.lib could not locate "FResDir".  This is a library created in version 2009 but called in a labview 7 application.  Something is different as i wasn't receiving this error before but i cannot put my finger on the cause.  I am assuming it cannot find a file resource it is pointing to but what the exact problem is, i don't know.
I have searched for this problem but nobody else seems to have it.
Anyone have any ideas?
(3,011 Views)
The DLL you have created seems to somehow use the FResDir LabVIEW manager function that LabVIEW 8.0 and newer exports. You can not run that DLL in a LabVIEW 7.x environment or earlier.
Rolf Kalbermatter  My Blog
(2,998 Views)
