How to define end of the multi-line string ?
Hi all!
I have a multi-line string, which I am handling by function "Pick line". The multi-line string may be different lenght. How I can to define    end of multi-line string ?
Thanking in advance!
(5,094 Views)
Hi MaxiMuz,
in LabVIEW a string is defined by it's length, there is no special "end of string" char similar to a zero byte in other programming environments!
The "end of line" char usually CR…
To define the length you could use StringStubset and provide the desired length!
(5,090 Views)
Accepted by MaxiMuz1979
You can use the Spreadsheet String to Array with a newline constant as the delimiter to convert your string to an array and then get the array size to determine how many lines are in your string.  Not sure if that is what you are asking.
aputman
(5,071 Views)
That to define the length I must to know this length. For example , I am reading txt-file  by "Read from Text File". Its is multi-line string, and I don't know how many the row it contains.
(5,054 Views)
Right click the Read from Text File and select Read Lines.  This will read each line of the file into an array index.
aputman
(5,049 Views)
Thanks for the advise !
But , if as delimiter to use the LF(line feed), in this case if last lines are empty, then a last line don't considered.
Properly to use CR (carriage return).
(4,998 Views)
