How to decode Google map polyline from 64base to decimal number
I need help decoding Google map polyline ASCII characters to decimal point. Can someone please help, I have tried few example on NI website but they do not produce desired results. I need something that is going to work like Googles decoder utility here. They have explanation how to encode here. It there some function in Labview that can do this.
(5,151 Views)
since you have the encoding mechanism totally explained, all you have to do is reversing it and then get the values you need
__________________
Engage! using LV2015
(5,101 Views)
Well, there are many ways to do all that. Here's a quick attempt that seem to produce the correct numbers. (within ~1e-5).
This is just a very quick draft of a very literal translation. I am sure it could be streamlined quite a bit more. 😉
(LabVIEW 2014. Let me know if you need an older version)
(5,081 Views)
Thank you.  Can you please uplod files for labview 2013.
Nermin
(5,046 Views)
Try this....
(5,026 Views)
Interesting topic!
Still I can't use it because I'm running Labview 2012... Smiley Sad
is it possible to convert the code to LV2012?
Thanks in advance,
Pieter Blok
The Netherlands
(4,728 Views)
