04-21-2011 01:29 PM
Hello there
I need help to create a tv remote that will be connected to a virtual tv in labview so the remote will control the channel, volume even the brightness of the tv itself? And how to put video into labview?
04-21-2011 01:46 PM
What exactly is a virtual TV? What is the source of the TV signal? You're going to need a minimum amount of hardware, like a TV tuner, unless you are planning to stream video from the Internet.
04-21-2011 11:08 PM
What i mean is i want to create a virtual tv that contains some video that will be putted in the labview. And there will be a remote tv that can change the channel (video), control the volume and brightness.
04-21-2011 11:38 PM
what he means is homework 🙂
04-22-2011 06:39 AM
it's not my assignment, it's my project to create a smart controlling remote that can control lights, curtains even tv but i don't know how to create the virtual tv
04-22-2011 10:02 AM
If you need to physically control external devices, you will need to start with something that can physically generate the IR just like the remotes you have right now. I know for a fact that an easily controllable (with an NI DAQ card) IR emitter is available at Radio Shack. An actual TV or use of a tuner card would need an IR sensor someplace. These are also readily available.
If you are going to simulate the hardware, then you are really going to be sending/receiving data from one application to another. There are many options for inter-process communication. TCP/IP, shared variables, etc. Search for discussions on the topic and you will find some examples.
04-22-2011 10:30 AM
Actually i'm using TCP/IP connection to connect between the tv and remote tv but the thing is i don't know how to create the logic for tv and the remote itself. Can you help me with some examples?
04-22-2011 10:45 AM
I don't have any examples. I worked with real hardware. You might send a command followed by a value - for example 'ChannelChange,Up' or ChannelChange,15'. Parse out the command, wire that to a case statement and inside the case statement, take an action based on the value passed in.
04-22-2011 10:46 AM
This is not a special requirement and not really different from any other iteractive LabVIEW program. LabVIEW deals very similarly with any kind of data sources, be it a manual change of a control on the front panel, the result of a calculation, a message coming in over TCP/IP, an analog signal from a DAQ, etc. etc.
How familiar are you with LabVIEW in general? If you know LabVIEW, you should be able to easily do all this.
04-22-2011 10:55 AM
I'm new for LabView, around two months i have learned this but i'm not very understand about Labview. But the basic how do you put the video into labview?
