How to create a square wave with a dynamic frequency
I am new to LabView and am attempting to create a program that takes a varying input voltage. It then uses this input voltage to output a square wave with a varying frequency, but constant amplitude. The goal is to have the program continuously check the input voltage and adjust the frequency in the output signal in response. I am using a BNC-2120 and NI PXI-1033.
Currently, I am working with these two programs (based on the NI examples) and am hoping to find a way to merge them. Please let me know of any suggestions.
Isabelle
Message 1 of 23
(1,971 Views)
BNC-2120 is a terminal block and PXI-1033 is a PXI chassis. You are missing the information on the module. Are you using a NI-6xxx or NI-4xxx DAQmx device?
https://tmesystems.net/
Message 2 of 23
(1,965 Views)
I am using a NI-6xxx.
Message 3 of 23
(1,937 Views)
What is the exact model you are using?
If your device supports HTWSP (DAQ Devices with Hardware-Timed Single Point Sampling Mode Support), it provides the smallest latency. See Application Case 1 in NI-DAQmx Hardware-Timed Single Point Lateness Checking
Message 4 of 23
(1,929 Views)
Apologies, I was misunderstanding the question.
This is what is installed on the computer. Is this what you were looking for?
Message 5 of 23
(1,892 Views)
Open NI MAX. Under My System >> Devices and Interfaces, you will see a list of NI devices connected to your PC. Show us what is the exact model of the device.
Message 6 of 23
(1,883 Views)
These are the models that show up under devices and interfaces. 
Message 7 of 23
(1,862 Views)
So you've two instruments,
  1. PXI-6534
  2. PXI-6255
Out of these which one does the BNC breakout board connect to?
Santhosh
Soliton Technologies
Message 8 of 23
(1,858 Views)
It connects to the PXI-6255.
Message 9 of 23
(1,853 Views)
Let me know if there are suggestions! Any help would be greatly appreciated.
Message 10 of 23
(1,825 Views)
