How to convert decimal number to binary number
Hi everyone, I'll start by saying that I'm still new to Labview. I'm communicating with a lock in 5210 and I need to display a certain error in Labview. Let me explain better, I send the N command from Labview to the lock in which will return an integer between 0 and 255. This number is the decimal equivalent of a binary number. However, I don't know how to convert this integer and especially how to convert this "error" to display it on the panel. Because, for example, if bit 3 goes to 1 then I should turn on a LED to specify that channel Y is overloaded. I'm attaching the part of the lock in manual and the first part of the (incomplete) Labview code (there is also management of the ?, because if it were to return this character then the command must be resent, and * establishes the end of the number). I hope you can help me.
Message 1 of 21
(1,296 Views)
Hi giuli,
Simplest approach (for people not used to boolean logic):
  • Use NumToBooleanArray to convert your U8 value into an array of 8 boolean elements.
  • Use IndexArray to index the required bits.
When you can apply boolean math rules to your data then you should use the AND function directly on your U8 integer value to mask bit3 (0d08 = 0x08 = 0o010 = 0b00001000)…
Message 2 of 21
(1,290 Views)
Ok thank you. So after accumulating the characters (in the while) and after getting the string containing the decimal number, I convert it to a number and then to a boolean array? Right?
Message 3 of 21
(1,276 Views)
Hi giuli,
Yes.
Do you really need to send and receive messages with your device on a "one byte after the other" scheme?
Have you watched this video yet?
Message 4 of 21
(1,260 Views)
Thank you so much!!
Message 5 of 21
(1,248 Views)
Maybe this is what you are looking for.
Message 6 of 21
(1,183 Views)
You are getting a single byte, that has the equivalent decimal value in the range of 0..255. You don't get 1-3 decimal characters (bytes)!
For that reason, you should typecast the single character to U8 and extract the bits
Message 7 of 21
(1,174 Views)
Here's a simple way to e.g. extract the active messages.
Message 8 of 21
(1,168 Views)
Thank you!
Message 9 of 21
(1,148 Views)
You can simplify the code using a cluster:
Message 10 of 21
(1,131 Views)
